HITACHI 32LD7200 Picture problem
Discussion in 'LCD & LED LCD TVs Forum' started by 54xhg, May 11, 2005.
Tags:
  1. 54xhg
    54xhg
    Feb 6, 2005
    Just bought the new hitachi 32ld7200,but the flesh tones seem too orange with a blueish/grey tint to them.I watch most of the tv through ntl cable it is also the same through normal tv and through my dvd recorder.I don't have any of the colour mangement,colour temperature or the colour decoding turned on.Can anybody help...Thanks.
  2. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    I don't have that trouble, NTL looks great on mine... Are all the scarts in completely? Not got a loose connection or anything?
    Want to list some of your settings? (although I can't think of any that would do that to the colour if you're not using any colour management)
  3. 54xhg
    54xhg
    Feb 6, 2005
    My settings are:
    Contrast +29
    Brightness 0
    Colour -9
    Sharpness -2
    Backlight +10
  4. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    That's not too dissimilar to what I've got... Top to bottom, these are my settings:
    Picture:
    Natural
    Contrast +15
    Brightness -5
    Colour -3
    Sharpness -15
    Colour Temp Normal
    Contrast Mode Normal
    Backlight 0
    Picture menu 2:
    Everything off
    Picture menu 3:
    Colour Temp Adjust
    Everything 0 (top 3 all the way to right, bottom 3 all centred)
    Colour Management
    Magenta +40
    Red +33
    Yellow +26
    Green +30
    Cyan +22
    Blue +40
    Colour Decoding set to RGB
    Red +33
    Green +33
    Colour -3
    Ignoring Audio, Function and Timer, obviously
    Setup menu:
    System 1
    Video Input
    AV1 Composite
    AV4 Auto
    That is just about every picture-related setting I've got on my set when on RGB scart for NTL. For me these settings give an excellent picture. The colour management ones should be the default I think, but check that they're the same, something funny might have happened to them.
    Failing this, have you tried changing cables?
  5. 54xhg
    54xhg
    Feb 6, 2005
    Cheers,
    Changed my settings to the ones you have and it seems to have done the trick.Thanks.
  6. matt_p
    matt_p
    Apr 7, 2005
    851
    28
    Nottingham
    +38
    Glad to help!
