Hitachi 32LD7200 - Confused on inputs
Discussion in 'LCD & LED LCD TVs Forum' started by Chorlton, May 9, 2005.
Tags:
  1. Chorlton
    Chorlton
    May 9, 2005
    63
    This is my first post and to be honest Im finding all the different input options confusing. I quite like the look of the 32ld7200 but Im confused on what connects to what, and I cant find a decent page to explain all the available inputs on this lcd.
    Anyone help?
    Does this set have HDMI? Is this HDCP?
    Also does it have a dvi or dsub connector (or both?). On the dvi is this also HDCP?
    Does it have component input for connecting a dvd player with progressive scan.
    Basically I have a PC. I want to connect along with a dvd player and NTL cable box. I have an amp and surround sound kit for home cinema so not too bothered about having the sound go into the lcd's speakers.
  2. neil c
    neil c
    Mar 25, 2005
    537
    +3
    It has HDMI - HDMI is HDCP by default, so no worries there.
    It has both DVI and DSUB, and the DVI is also HDCP.
    It also has 3 scart inputs (2 are RGB), 1 S-Video and finally there is 1 component input.
    What a selection!
  3. Arob
    Arob
    A very well connected set.
    However I would point out that there have been problems getting 1:1 with DVI from a PC. I am currently using my 32LD7200 connected to a PC with a ATI Radeon x800xt, using DVI. The maximum resolution I can get is 1024x768, which can be stretched to fill the screen. There was an earlier thread saying Hitachi were looking at this problem. I have not yet tried with DSub, no longer have one of those leads, but I here that is ok.
    Anyway I am very happy with a stretched 1024x768, doesn't really bother me for the moment. Maybe someone will find a fix for this sometime. The set is fantastic in pretty much every other way.
  4. snark
    snark
    Jan 5, 2005
    43
    Try this linklink
  5. Chorlton
    Chorlton
    May 9, 2005
    63
    Thanks for the info. Im using an epia board at the moment as a media center and it only has dsub or svideo. Although my gaming pc has dvi.
