Hitachi 32LD6600 VGA-> PC flickering/banding
Discussion in 'LCD & LED LCD TVs Forum' started by djdoddy00, May 4, 2007.
Tags:
  1. djdoddy00
    djdoddy00
    My dads just bought a graded hitachi 32LD6600. I connected it to the PC (geforce 4200ti vid card) via the d-sub vga socket on the lcd to the d-sub socket on the card. The resolution was set to 1366x768 60hz as the native resolution of the lcd. My problem is that there seems to be horizontal lines running down the screen making it appear to flicker. How would I solve this? Should i try hdmi -> DVI or component maybe? or is it simply a problem with the resolution settings? As this is the first LCD TV i've had im not sure what to expect and cant really tell whether it may be a fault in the TV or not. Also, he has an old SD cable digital box that only seems to have a scart connection on the back. Would a good quality scart lead suffice here or is there other options?
    Thanks alot.
  2. djdoddy00
    djdoddy00
