Hitachi 17LD4200/4000 response time?
Discussion in 'LCD & LED LCD TVs Forum' started by baku, Nov 3, 2004.
Tags:
  1. baku
    baku
    when you click "SHOW TECHNICAL SPECIFICATION" for this screen it shows 17LD4000 specs on official site. I looked for info on brochures, user manual etc... but they only have added 17LD4000 not 17LD4200 model.
    In the manual it says 25ms response time (17LD4000) but on technical spec it says (TR + TF) 16ms. I'm very confused please help...
  2. gaz@manc
    gaz@manc
    I've found a product listing through Price Runner (can't remember which retailer exactly) but they advertised response time of 16ms....I'm very tempted cos its just about in my budget range.
  3. phancey
    phancey
    Dec 13, 2004
    22
    did you buy this?
    I am looking at ld4200 or ld4220. Looks like the 4200 doesn't have SCART and is generally for use as a monitor but with TV whereas the 4220 is the other way round - is this right? But with the 4200 at less than £300 - is it still a good TV? Better than a Philips 15PF8946?
    cheers,
