hitach32pd5300 & pioneer 575 dvd
Discussion in 'Plasma TVs Forum' started by chris210972, Jan 19, 2005.
  1. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    hi can anyone help me.
    i have just received this tv today and am having problems with the dvd picures from my pioneer 575 dvd player.
    when i connect the 2 together vis my ixos component cables the picure is a yellow/green.
    it works fine scart to scart but i just can;t seen to get the proper pictures using the component leads.
    can anyone help me??
  2. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    can antone help? :confused:
  3. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    hmm, no one had or seen this problem?
  4. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Is the DVD player set to output RGB or YUV on component?
    I'll be honest in that I don't know what the difference is but, on my 42PD5300, the DVD player has to be set to YUV on component to get a picture.
    HTH
    John
  5. saintalan
    saintalan
    Dec 7, 2004
    528
    28
    Windsor
    +47
    Possibly a damaged component cable? Have you tried disconnecting one at a time to see if there isa differnce in th picture colour?
    Alan
  6. snappyq
    snappyq
    Jun 28, 2004
    190
    hull
    +9
    hi there
    i have a 425200 with the same dvd player,it might sound a silly qestion but have u gone into the dvd menu and changed it to prog scan component from interlaced i did this with mine and it was great also when u put the component cables into the tv did u also use a video cable (yellow ends) as well. until i did this my picture was all over the place.
    hope this helps
    cheers
    snappyq
  7. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    snappyq - not sure what you mean by a yellow video cable - the component cable carries the video signal, there is no need to use any other cables.
    As regards switching progressive scan on, IMHO there is no point with the Hitachi screens. As the Hitachi is based on an ALIS panel which is inherantly interlaced, progressive scam makes, so far as I can tell, no difference.
    I've done a lot of tests with my 42PD53000 and an Arcam DV79 DVD player with a number of DVDs. I got my wife, who knows nothing about this sort of thing, to tell me which picture she preferred as I switched between progressive and non progressive. Without knowing which was which, she picked the non progressive signal every time.
    John
  8. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    it could be the cable.
    i have tried 3 different dvd players tonight all with component outputs.
    they are all the same, the picture is yellow.
    it doesn't matter whether the dvd is set to interlace, component or pro scan it seems to give the same picture.
    could be the leads (hopefully).
    anyway i've got a hdmi player on the way so hopefully when hooked up via hdmi/dvi cable i'll get the picture i'm hoping for.
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I'm not sure I know how you're going to do that on a 5300 ? :rolleyes:
  10. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Nick's correct, the DVI port on the 5300 is taken up by the connection from the panel to the media box so can't be used. Best connection you'll get is component.
    John
  11. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    :oops: :oops: sorry, its a 5200 i've got (typing error).
