Hissing from Panasonic TX32PD50C
Discussion in 'General TV Discussions Forum' started by bassbear81, Jan 13, 2005.
Tags:
  1. bassbear81
    bassbear81
    Dec 8, 2004
    30
    HI,
    Im new to this home cinema game so appoligies if this isa basic question.
    Just recieved the Panny TX32PD50C and love it. However there is a hissing noise coming from the right hand side (as you look at it), the loudness seems to vary, but when watching quiet scenes in movies it really is noticeable.
    I called the place I got it from and was told this is normal for a Tv of this size, its just the transformer and that the loudness will vary depending on what sort of picture im watching.
    Can anyone confirm that this is correct.
    Andy :)
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Hello Andy and welcome to the Forum. :)
    In a word: "Rubbish!"
    I'm afraid they're trying to pull the wool over your eyes.
    What you are hearing is a discharge from the EHT.
    It's 25,000 volts, which possibly explains why they're not keen on touching it. :laugh:
    Get a technician in, or better still, get it replaced.
    Good luck! :thumbsup:
  3. bassbear81
    bassbear81
    Dec 8, 2004
    30
    Thanks for a quick reply.
    What is EHT?
  4. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    Extra High Tension(High Voltage!) This could also be the scan coils and/or some other component rersonating. I would doubt it to be EHT as this is usually a loud "pop" but anything is possible. Any noise is subjective IMO and diagnosing opver the Internet is very hard.........
  5. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    EHT flashover is indeed a loud "pop", in fact a VERY loud "pop"!
    But Andy described it as a "hissing" noise, which sounds more like EHT tracking or discharge to me.
    Resonating in the line timebase shows as a high pitched whistle of 15,625Hz.
    It used to give me a headache although 405 lines was even worse! :devil:
    Isn't it amazing how far back the memory extends for some things...
    :laugh: :laugh: :laugh:
  6. daver555
    daver555
    Dec 8, 2004
    45
    Sandhurst, Berkshire
    I noticed a hissing when I bought my 32PD50C. I also have a Panny digital landline phone which was close to the TV. I moved the phone and it reduced the hissing significantly though not completely. Dont notice it anymore though.
