hisense h65n6800 streaming problems
hoysy7
just got this tv today and cant seem to work out how to connect the tv to my computer to stream films which i have downloaded.my last tv was fine a samsung i used seviilo and that worked fine you just opened seviilo on the input on the tv
bubblegum57
Samsung has better support, I doubt, but don't know if serviio will work on Hisense. Does hisense have an app for serviio? again I doubt it.
you might need to have a rethink about your setup.
eg get a cheap android device, install kodi on your pc, then plug you pc vis hdmi.
Have a look at serviio support, here is a link to get you started
Serviio • View topic - HOWTO: Provide supported formats of a device
shotokan101
hoysy7
thanks ive sorted it just had to press the home button then select the media i wanted to stream works a treat
