Hisense H50N6800 Youtube freeze fix
Clive H50N6800UK
Youtube Freezing. Hope this will help with the problem I had with youtube freezing after a couple of minutes when playing. ( the TV kept crashing when this happened ).
TV was using version V0001.01.00a.I0102. When I did a search for an update on the TV, it said it was upto date ?
So I called Hisense who said there was an update available to fix the problem, and would post it on a USB stick for free.
When it arrived I had no luck loading it, using there setup procedure.
I then searched the internet for help, and turned out they had installed it on a FAT16 USB stick when it should have been a FAT32 USB.
So I downloaded the file on to the Desktop of my computer.
Then I Formatted a FAT32 USB ( clearing all data on that USB ). Then loaded the file onto the FAT32 USB.
File was then able to update TV to latest version. Youtube now works perfectly.
