Hisense 65U7QF or LG 65UN81003LB
Kroos123
Hello, I'd like to buy a new TV and I'm considering these 2 models:
Hisense 65U7QF
LG 65UN81003LB
The TV will be used at night, sitting straight ahead, for movies, TV series (Netflix, HBO GO) and sports (sport sometimes during the day), and maybe 10% time for Xbox Series S. I know the difference between VA and IPS, but will actually in this case LG be much worse choice? I am afraid of the motion problem on the Hisense, but maybe unnecessarily?
Maybe another TV would be a good choice at a similar price?
Dodgexander
The only motion problems I know of on the HIsense is a bug where your motion settings don't get saved for each app. Fix is to disable fast start up on the TV or use external smart TV. There is also a blur issue, but this isn't something you see really in sport, its more in dark scenes in movies where there can be red trails.
Hard to know what you'll make of it without owning the TV. If you don't need better viewing angles then the Hisense is better in every area otherwise compared to the LG, especially if you're viewing at night, and if you intend to use HDR.
Alternatives are also in my guide here:
