Just been doing some reading up on the difference between direct and edge.Just an update on the 5750, it's seems that though it is direct led there is no local dimming meaning the leds' are just permanently lit which isn't ideal for deep contrast and black levels so think ill try to hunt another m7000 out or find a refurbished 65ks8000
There is one you can get called something like smart IPTV , you go to the website to input your links and they show up on your TV . Tried it ages ago but not near my TV now to check name , If you need me to i will find it tomorrowSorry for the off topic but I couldn't find any other thread for this specific device. So here is my question:
How can I watch iptv channels in this TV? I can't find any iptv app...
Please help me here
I know SMART IPTV and I use it with onother TV (Samsung) I have. The problem is HISENSE store has no iptv apps to install.There is one you can get called something like smart IPTV , you go to the website to input your links and they show up on your TV . Tried it ages ago but not near my TV now to check name , If you need me to i will find it tomorrow
I have it on my hisense TV with the foxxum app store but hisense have gone onto opera app store with newer TVs so sorry it may not be available on yoursI know SMART IPTV and I use it with onother TV (Samsung) I have. The problem is HISENSE store has no iptv apps to install.
That is ridiculous... I have to buy a TV box to turn my top high tech SMART TV into a decent TV....I have it on my hisense TV with the foxxum app store but hisense have gone onto opera app store with newer TVs so sorry it may not be available on yours
You need a cheap android box plugged in then you can install what you want , Kodi etc
