Quantcast
Hisense 65m7000 replacement remote
shemsha
Hi all.
Hoping for some help.
My 65m7000 remote started to malfunction.
Some of the buttons stopped working.
The remote model is EN2B27.
Any suggestion for a decent replacement? All the ones on ebay/Amazon seem fake with mixed reviews.
Any suggestion? Any Universal remote with a Netflix button? Perhaps a remote that is intended for another model?
Thanks!
davidcrofter
The ones on ebay are fine. Hisense have been using a similar remote control for approx 5 years with just a few tweaks each year.
shemsha
Thank you.
Does that mean EN2A27 remote model should work? Or better to stay with EN2B27?
The EN2A27 has higher availability on Amazon and would arrive faster compared to eBay.
davidcrofter
Stick with the specific remote for your model as there is no guarantee different ones will be compatible.
Similar threads
