It seems every single manufacturer still has bad QC issues in 2016. Pretty crazy situation really.Tomorrow i will be getting my 3rd set. Hope its ok or I'm giving up !
I've just had a thought - the one I am returning The 50k321 is on a wall bracket cantilever style - with this one being a 55inch will I need a new wall bracket or will the holes be in the same place - does that make sense ?
This is the bracket.....Invision® Ultra Slim Tilt Swivel TV Wall Bracket Mount - For 24 - 55 Inch LED LCD Plasma & Curved Screens - Now Includes 1.8m HDMI Cable (HDTV-E): Amazon.co.uk: TV
Dave
Anyone with a M3000?
Very odd issue i've noticed (using it as a pc monitor)... it appears as though there is quite a large gap between the lcd screen and the backlight, so much so that it looks like the image is on a seperate layer to the background!
If you look at the image close up and at an angle, it looks as though text etc is "floating" above the background in Windows.
Anyone else noticed this? It's making this tv pretty useless for pc use, as a result of this is that part of the image is being cut off around the edges.
Also, no PIP?! What gives with that?!
I bought this set a few days ago,
I like it alot. But I seem to have something called the "Soap Opera Effect"
Can someone help me with settings to turn this off.
thank you
