Hisense 55/65M7000 ULED Owners Thread
Discussion in 'Hisense TVs Forum' started by technomen, Mar 18, 2016.
    1. MrPink82
      MrPink82
      Nov 23, 2016
      13
      4
      Germany
      What is the last Firmware i should use? I m curretly on GER 0601.
      Best regards
    2. Nobbler
      Nobbler
      Jan 23, 2012
      7,599
      5
      167
      +3,079
      Depends where you are...
    3. MrPink82
      MrPink82
      Nov 23, 2016
      13
      4
      Germany
      Germany
    4. Nobbler
      Nobbler
      Jan 23, 2012
      7,599
      5
      167
      +3,079
      Then I believe that's the one. I do t keep track of firmware- sorry
    5. alza1
      alza1
      Jun 30, 2017
      12
      Melbourne, Australia
      why does location matter?
    6. Nobbler
      Nobbler
      Jan 23, 2012
      7,599
      5
      167
      +3,079
      Dir the apps I believe. Some are available in some countries but not others.
    7. MrPink82
      MrPink82
      Nov 23, 2016
      13
      4
      Germany
      Thank you Nobbler!
      Netflix HDR is possible now with PS4 Pro and the Netflix App.
      Now I hope that the PS4 will support HDR on Amazon App in the near future.
      Than i m fine. HDR Gaming is possible. Flashing Bars are solved.
    8. alza1
      alza1
      Jun 30, 2017
      12
      and to confirm you're on UK h0524 with a 55"? where can i get that firmware?
    9. Nobbler
      Nobbler
      Jan 23, 2012
      7,599
      5
      167
      +3,079
      It's buried in this thread somewhere and yea I'm on that fw
    10. kimberlin
      kimberlin
      Jul 3, 2017
      267
      46
      UK
      +142
      This is the link which is on someone's G Drive and was posted from this thread. Obviously you download at your own risk.
      upgrade_loader(HE55M7000UWTSG-BT 709 WCG-no LD).pkg
      Clearly as Nobbler alluded, if you are in another country and you apply a firmware fix that wasn't intended for your location, you may end up losing certain functionality/Apps. You may also invalidate any warranty, so it's all at your own risk. If you brick your set, it's your problem to solve.
      I've had this firmware on my own set since Hisense sent me a link to it. Not had any issues since, though arguably, I'm no TV colour expert, but the reds are just fine for me on Native, everything on default. Not mucking about with it any more. Cheap panel. It is what it is!
    11. Makefish
      Makefish
      Oct 17, 2016
      15
      Hampshire
      +3
      Just attempted a firmware update, followed the procedure that Hisense sent me but TV now completely frozen with a blank screen and red power light on.
      Doesn't matter what I try nothing, even stranger is the red light stays on whether it's plugged in or not? Even tried a hard reset by but still nothing!
      Any suggestions to get me out of this mess would be appreciated (I have the 65).
    12. kimberlin
      kimberlin
      Jul 3, 2017
      267
      46
      UK
      +142
      Which firmware have you attempted to apply to your set? Which country are you in?
    13. Makefish
      Makefish
      Oct 17, 2016
      15
      Hampshire
      +3
      UK, was a link that Hisense sent me to download a file and unzip to a memory stick. File ref: UK_HE65M7000UWTSG_pkg_20170110.tar
    14. kimberlin
      kimberlin
      Jul 3, 2017
      267
      46
      UK
      +142
      Oh, well as it's an official Hisense update link, then one would have hoped it would have applied the firmware correctly. Nothing I can personally advise you then, except if you can't do a factory reset and it's bricked, contact Hisense UK (good luck with that!) and assuming you're still under warranty, see if they'll fix it.
    15. gabriyzf
      gabriyzf
      Jun 19, 2015
      221
      italy
      +45
      I'm using nobbler last settings.
      Not bad at all, not bad.
      Next days I will tell you more.
    16. Ryman
      Ryman
      Jul 28, 2017
      34
      11
      Birmingham, UK
      +6
      @Nobbler Thanks for the new settings as always greatly appreciated. Look good on my 55" with the H0524 firmware. :smashin:
    17. Peyta
      Peyta
      May 19, 2017
      48
      Germany
      +6
      heres the answer i received from german facebook support regarding BT709 issues for the 65 model (didnt put much afford in the translation):
      “Hi ….the short explanation for the unnatural color reproduction: „the unnatural strong red tone results from the built in panel. We choose a panel, where 70% red luminance is used as BT-709 value. Therefore, the red drift is less noticeable on colors with a value less than a 100% share. The result is, that red tones with high luminance look stronger saturated than tones with lower luminance. Unfortunately there is no software worldwide, which could solve this problem completely. That’s the reason why we decided for the previous described settings. Were sorry, that we don’t have better news for you.
      Kind Regrads
      Hisense Germany”
    18. Nobbler
      Nobbler
      Jan 23, 2012
      7,599
      5
      167
      +3,079
      If that's the case go into the advanced picture settings- colour tuner and turn the red brightness down by 2 clicks on red . However on the 55' inch panel this introduces flashing on the picfure...win some lose most with Hisense it seems.
    19. Obsgamer
      Obsgamer
      Sep 17, 2013
      537
      43
      +125
      Search this thread for another firmware for your TV , any will do for now and try to apply that
    20. williest77
      williest77
      May 15, 2017
      45
      11
      italy
      +8
      new settings only for night mode? day mode old settings are ok?
    21. Nobbler
      Nobbler
      Jan 23, 2012
      7,599
      5
      167
      +3,079
      It doesn't matter - there's no need for different settings unless your room is flooded with light by day and pitch black at night. The gamma reads 2.4 which is good for a room that isn't light proofed. You should only use my latest settings as anything I posted before them I didn't account for the white balance being broken so they are now redundant
    22. thedotlal
      thedotlal
      May 14, 2010
      282
      +6
      I have a feeling my 65 is on the original factory firmware, the version is V00.01.00a.H0110
      I'm in the UK and tried updating via internet in the menu/settings which tells me I'm running the latest firmware. Is this correct?
    23. koskos
      koskos
      Sep 14, 2017
      IE
      +3
      which FW is this? 1016 from SA?
    24. koskos
      koskos
      Sep 14, 2017
      IE
      +3
      latest is 1016 from SA
    25. Craven68
      Craven68
      Dec 14, 2016
      359
      46
      France
      +174
      @Nobbler These setting are really the best !!! they look so good !
    26. Nobbler
      Nobbler
      Jan 23, 2012
      7,599
      5
      167
      +3,079
      That's because I finally found a way of calibrating it around it's faults. With other Tv's you calibrate them and it's done - with this one you get different results every time because the white balance is broken - the 10 point anyway. But because of a dip in brightness between 50 and 70% you need to use the 10 point to get the results...
    27. ermeric1
      ermeric1
      Dec 26, 2016
      47
      Cape Town, Western Cape
      +11
      Thanks for these settings Nobbler. So there's nothing for the lower values?
    28. Nobbler
      Nobbler
      Jan 23, 2012
      7,599
      5
      167
      +3,079
      I can't accurately measure lower than 20% with equipment I'm afraid...
    29. Squarty
      Squarty
      Jun 2, 2017
      58
      11
      Italy
      +10
      What languages are available in the firmware 1016 from SA ?
    30. alza1
      alza1
      Jun 30, 2017
      12
      @kimberlin do you have the link to the firmware Hisense sent you? as you point out, the drive files could've been edited
