I need a new bedroom TV and just about to buy the 50M3300 which seems a crazy good price for what you get. Reading the total thread on the M3300 on the main forum- people seem really happy with it so is it really worth spending any more ?
The space can only fit a max of 50" and there is an old Samsung M87 40" (2007 I think I bought it) -
i assume i am going to see a massive jump in quality.
I will be using either the inbuilt Freeview HD or my Humax YouView box with an aerial. I also have a PS4 with HDR update and will update to PS4 Pro. Also have an AppleTV 4.0 using InFuse which is for everything else.
How bad is normal SD TV going to be a 4K screen ? worse than i have now on my Samsung M87 ?
Does anyone know the difference between the M3300 and M5500 models, from what i can find only seems to be PVR ? and the 5500 seems not available much. Is this a good choice or should i really spend a bit more money and get a Samsung / Sony / LG ?
