TheGamer147
Established Member
Hi what settings do you you for sky box
I'm using the cinema day / night settings at the very top of the list for everything on sky q.Hi what settings do you you for sky box
Thanks how are you finding the TV what it like with motion when watching football.I'm using the cinema day / night settings at the very top of the list for everything on sky q.
Plus sky q set to output at 2160p
I'm don't watch sports but from what I've seen its ok. It's a budget TV so keep your expectations low and you can't go wrongThanks how are you finding the TV what it like with motion when watching football.
I'm away for a long weekend so can't check for you I'm afraidCan you check something for me on the BBC iplayer smart app are you able to view live TV when going to channels then BBC one on app.
Hi mate Just set up TV can you check something for me when free when playing a HDR video on YouTube does it come up telling you it running HDR mode..mine doesn'tI'm away for a long weekend so can't check for you I'm afraid
It should do. Search for the hdr channel on YouTube and play a video. Check your picture mode and it should be on either hdr day or night mode. You won't get any sort of popup on screenHi mate Just set up TV can you check something for me when free when playing a HDR video on YouTube does it come up telling you it running HDR mode..mine doesn't
When I choose backlight setting on hdr Day it only let me choose off low or highNo problem happy to help!
I don't see much difference in the newer firmware either but personally I just prefer to be on the latest version.
Pressing up on the remote while in that setting, lets you adjust the actual backlight from 1-100. It's an odd setup.When I choose backlight setting on hdr Day it only let me choose off low or high
Hi mate what settings do you use on Xbox when not playing a HDR gameI'm using the cinema day / night settings at the very top of the list for everything on sky q.
Just the normal cinema day settings that I'm using for sky QHi mate what
Your blacks probably look more greyish but if that's what you need to do to overcome the issue then go for it. The settings I posted here are only guidelines to get you started, enjoy your new TV !Hi everyone,
Just bought a Hisense A6140 and used this settings. The image looks good, thanks for that !
However, my TV is located next to a window and the TV’s brightness seems a bit too low, which generates quite a lot of reflection.
Is there any downside to setting Backlight to 100 in Cinema Day mode ?
That would help with this glaring issue but I guess there is a reason for setting this value to 30.
Could it be related to what your pc is outputting rbg or yuv maybe?I just got my Hisense H65AE6100UK 65-Inch delivered yesterday and it is a great value piece of tech. It replaced my Hisense H60NEC5600UK 60-Inch and i can tell it is a better bit of kit.
One thing the 5600UK did have was a game mode. If i use the settings lisnalee recommends then yes TV/film etc are looking great but when gaming on my PC the blacks lack depth. I have changed to dynamic mode for when gaming and turned any extra processing off or down etc and it looks better now. Any further hints on what further settings i can use while gaming ?
If that’s the only downside then I’ll give it a try and see how it performs.Your blacks probably look more greyish but if that's what you need to do to overcome the issue then go for it. The settings I posted here are only guidelines to get you started, enjoy your new TV !
I thought I post my own settings for this TV to give any new owners a starting point to work from. These have been done from various calibration discs and tweeked over the weekend watching a ton of different material. I have put them into my own 65" and my brothers 43" and they produce a very impressive picture for the vast majority of content. I am currently running content from Sky Q, PS4 Pro, Xbox One X, Netflix & Amazon
I'm running software version I0926 as of Dec '18 and so far everything is running perfectly fine.
Incase anyone is looking for the Sky Q code for the remote its 2427. Here is my settings.
First things first hdmi 2.0 format set to enhanced.
Cinema Day:
Backlight 30
Brightness 51
Contrast 50
Colour 52
Sharpness 0
Colour Temperature Standard
Colour Tuner: Green ( I've only adjusted Green, the others seem fairly spot on to me)
Hue 0
Saturation 6
brightness -1
Gamma 2.2
Everththing else is set to off were possible.
Cinema Night:
Same as above but backlight reduced to 15
HDR Day / Night:
Backlight 100 (auto selected)
Brightness 49 (reduced)
Contrast 60 (increased)
Colour 52
Sharpness 0
Gamma 2.2 (auto selected)
4k Blu Ray HDR from Xbox One X:
HDR Night
Brightness 49
Contrast 65 (increased)
Colour 42 (decreased)
Sharpness 0
I've requested it from hisense last week and still waiting on the USB to arrive. Hopefully it turns up in the next day or 2.Have you got latest software update from hisense J0926... Any chance of updated settings?
