Brand:Hisense ModelDP4211EU Descriptions:42 inch PLASMA color TV Display Size:42 inch(106cm) diagonal 16:9 TV RF SystemK/I/BG/L/L' TV Colour System:RF: PAL SECAM AV: PAL/NTSC/SECAM Channel Coverage:200 TXT:10 Pages For European Languages Stereo/AV:NICAM A2/SCART TUNER:Built-in Tuner Volatage synchronized Audio / Speakers:20 Watts(2~10W) Voltage:120V-240V 50/60Hz 3-prong polarized plug AV input:1 AV Input; 1 S-terminal input; 1 Y Cb Cr/Y Pb Pr mux input. Graphic input:1 analog RGB D-SUB 15pin input Audio input:1 AV audio; 1 PC audio OSD:English German French Spanish Italian Pixel Pitch:Horizontal 1.095 x Vertical 1.110 mm Display Pixels:Horizontal 852 x Vertical 480 Pixels(1Pixel=1 R,G,B cells) Pixel Pitch (mm):0.297 x 0.297 Pixel Type:R,G,B Stripe Effective Display Size:Horizontal 932.94 mm x Vertical 532.8 mm [36.73 inch(H) x 20.98 inch(V)] Number of Colors:16.77 milion colors Peak Brightness:Typical 1000 cd/u Contrast Ratio(in dark room):Typical 3000:1 Viewing Angle:Over 160 Power Consumption (W):420W Panel maker:Samsung SDI V3 Ebuyer - £900.00
I'm pretty sure they had these in Maplins as well a while a ago ? None too impressive. £900 is appealing but in the long run it makes No-Sense
