HIMedia Q5 Android Media Player Review
Discussion in 'Video Streaming Boxes & Services' started by hodg100, Jun 26, 2015.
    1. hodg100
      hodg100
      Reviewer & News Writer
      Aug 8, 2005
      14,105
      3
      4
      +4,468
    2. nicfaz
      nicfaz
      Nov 8, 2008
      248
      +50
      Nvidia is making great claims for it's Shield Android TV, including 4K Netflix playback. Are you lining yourselves up for a review of those when they are out? Bit more expensive but you get a lot more too.
      (Off to check whether my Shield Tablet can stream Netflix in 1080p / 7.1 if connected to the telly)...
    3. usenetz
      usenetz
      Dec 6, 2005
      742
      46
      +149
    4. hodg100
      hodg100
      Aug 8, 2005
      14,105
      3
      4
      +4,468
      We definitely want a look at that, yes. Problem is, that will probably end up costing me as I'm pretty sure I'm going to want to keep it.
      I thank you. Now fixed.
    5. nicfaz
      nicfaz
      Nov 8, 2008
      248
      +50
      I see!
      I did check and my nvidia shield tablet streams 1080p, so not all androids are stuck with 480p. Nvidia must have a special version...
    6. dazm41
      dazm41
      Mar 19, 2007
      1,667
      worksop england
      +463
      nice to see a review of this box i will agree with you if all you want is a streamer for locally stored films with all the trimmings ,2d, 3d iso and full hd audio you can't find a better box and good customer support .
    7. Talgo
      Talgo
      Oct 2, 2010
      614
      2
      46
      +122
      Where would one buy one from ? For purely movie playback would this replace a htpc in a high end (ish) system .. What about color space and YCrCb 4:4:4 ??? Outputs
    8. dazm41
      dazm41
      Mar 19, 2007
      1,667
      worksop england
      +463
      HiMedia Q5 4K3D - futeko.com - UK Android Box, Mini HTPC, XBMC, Miracast, Airplay, Airmice. can buy them here couldnt advise on colour space and YCrCb 4:4:4 but if you mean digital there are 3 USB ports (1 x 3.0. 2 x 2.0), a full-sized SD/MMC slot, a HDMI output, a LAN port and both coax and S/PDiF digital audio outputs. There’s also L/R stereo jacks which can be used this is taken from the review i would also had here that what not mentioned in the review is that player supports hardware decoding h.265 4k up to 4k 30 frames per second.this a very capable android box which would perform in a high end system .you can also buy them on amazon http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=HiMedia+Q5+4K3D
    9. looun
      looun
      Jun 26, 2015
      27
      rome
      +7
      The big advantage of q5 is Image and Display Processing (Imprex Processing Engine), with my plasma picture quality is awesome.
      Q5 have replace my PCH A-400(top player) : more picture quality , more fast better jukebox(kodi) , better Full 3d experience.
      Nice app Himedia Control for remote control from smartphone.
      Good choice is also Himedia M3 less CPU power plus Bluetooth, but less cost.
    10. Johnny.G
      Johnny.G
      Dec 10, 2002
      732
      4
      46
      Nottinghamshire.
      +155
      @ looun ..... absolutely agree. On my 120" dia screen from a Sony es55 PJ the image is very very good, easily on par or better than from my Oppo 103 BR player, and far better than other media players that i have used over the last few years. Very impressed with this unit and Dolby Atmos is detected & played back without problem. I only use the unit to pull .iso movie rips from a Synology nas to the cinema room , the other features on it are not too important to me so doesn't worry me .
      I'd have no hesitation in recommending them.
      Edit ..... Also meant to say thank you to Mark for the good review :smashin:
    11. hodg100
      hodg100
      Aug 8, 2005
      14,105
      3
      4
      +4,468
      Not exactly a special version but Netflix doesn't grant the right to stream HD to many Android devices. I'm led to believe that a device must have projected sales of 3 million units, per annum, in the US before it's allowed on the list of permitted platforms.
    12. connect
      connect
      Aug 27, 2003
      811
      46
      +201
      So with this box am I correct in thinking that you can rip the whole 3D blu ray. Put it on the HDD and then you have the full experience of an original blu ray. Extras, Menu layout, no loss of quality, subtitles, various audio formats etc? Without the load times and switching discs. All of it!? How does the picture quality compare with a stand alone blu ray player? I like buying the blu ray discs for no loss of quality and because I like to have the box. So I wouldn't stop that but I like the sound of having it all in one place at the same time.
    13. looun
      looun
      Jun 26, 2015
      27
      rome
      +7
      FUll 3D blu ray iso and BDMV(blu ray directory) are supported,but only with lite menu(audio ,subtitle, chapters ) no "FULL" experience of an original blu ray; because
      from a few year only less player can have Full menu.
      Picture quality compare with a stand alone blu ray player is like or near oppo player.
    14. Mr_Mojo_Risin
      Mr_Mojo_Risin
      Mar 28, 2006
      513
      3
      2
      All Over
      +278
      LOOUN, did you manage to sort out the HDMI-CEC problem on this unit?...I wish to connect through an AV unit too you see.....
    15. looun
      looun
      Jun 26, 2015
      27
      rome
      +7
      Q5/Me not support CEC.
      If you talk about other unit have problem with CEC when Q5 is plugged to AV-receiver.
      I think is hardware problem of Q5 HDMI port, the only solution now is CEC Less HDMI Adapter
      adapter like this (10-15€ on-line store) , with this adapter there is not more interference.
      [​IMG]
      or
      Lindy HDMI CEC Less Female to Male Adapter: Amazon.co.uk: Electronics
      The problem has sent to himedia ,awaiting answer.
      • Like Like x 1
      • Thanks Thanks x 1
      • List
    16. looun
      looun
      Jun 26, 2015
      27
      rome
      +7
    17. woundedgoat
      woundedgoat
      Jul 20, 2010
      15
      When it says this player will pass 7.1 audio would it also be able to do 5.1.4 Dolby Atmos? Theoretically 9.1?
    18. Johnny.G
      Johnny.G
      Dec 10, 2002
      732
      4
      46
      Nottinghamshire.
      +155
      ... my Q10 passes Atmos so will / should, the Q5.
      Iv'e used 7.4.4 Atmos as well as 9.4.2 Atmos through my NAS >Denon 7200> Q10 without any problems :smashin:
    19. woundedgoat
      woundedgoat
      Jul 20, 2010
      15
      Hi Jonny, Thanks for that info. I bought one yesterday and panicked a bit when I read it was 7.1 lol.
      Its arriving tomorrow hopefully, just need a Atmos ready amp now!
    20. Se7en
      Se7en
      Jul 2, 2012
      4,238
      +583
      I have the q5 it runs atmos no problem once software is firmware is run for himedia wrap.
      So yes johnny G is right q10 and q5 do passthrough atmos
    21. woundedgoat
      woundedgoat
      Jul 20, 2010
      15
      Great stuff guys, set my mind at ease!
      One other thing how is it at streaming Bluray ISO over a wired network connection?
      Would SMB or NFS share be best? I will be using Kodi as the player.
    22. Johnny.G
      Johnny.G
      Dec 10, 2002
      732
      4
      46
      Nottinghamshire.
      +155
      Se7en, looks like your up and running then chap :thumbsup:, @woundedgoat, thats how i use my Himedia player for my purchased Blurays ... Rip Bluray with AnyDVD HD to .ISO > NAS > Q10 SMB > Denon 7200 > Dirac 88A > Pwr/Amps > Sony PJ > Darbee > 120" AT screen. Still well pleased with the Himedia unit & don't regret buying it one bit after i saw dazm41 singing it's praises. :)
    23. Se7en
      Se7en
      Jul 2, 2012
      4,238
      +583
      Im streaming blu ray iso via nas via smb share no problem.
    24. Johnny.G
      Johnny.G
      Dec 10, 2002
      732
      4
      46
      Nottinghamshire.
      +155
      .... what i did find useful to have, for me anyway, for inputting web url's etc into the Himedea was a £19.95 full size wireless keyboard, mouse & mini usb dongle kit from PCWorld instead of the fiddly airmouse thingy ... made it far more user friendly :)
    25. looun
      looun
      Jun 26, 2015
      27
      rome
      +7
      you can't use kodi internal player(dvdplayer) , you must use himediavideoplayer if you want 24p, audio hd, full 3d and better picture quality.
      Kodi can be use for jukebox download subtitle cc.
      If you want kodi player buy htpc or rapsy.
      with last firmware there is some trouble with 3D ghost:
      3D Ghosting
      What do you think?
    26. Mklad
      Mklad
      Sep 29, 2013
      2,055
      Milton Keynes
      +370
      After seeing the review i purchased one, and i must say that I'm over the moon with it. It played everything i have put on, even film's with atoms sound. Well happy.
    27. Scotty Pro
      Scotty Pro
      Dec 27, 2009
      1,444
      Washington, Tyne & Wear
      +157
      Just came across this thread and the Q5 box looks like what I'm needing. At the moment I have two 3Tb external hard disks plugged into my Yamaha Blurry player with all my MKV files on them which feeds into my Marantz amp and then onto my TV. I rip the blu's on my mac and then plug the external drives in and copy them over then reconnect the drives to my Yamaha.
      I know, its a bit long winded but at the moment thats about the easiest method.
      Now, if I was to get the Q5 I could leave the drives connected to it and copy my rips via the network over to it, saving me unplugging all the time, or does it not work like that. If it doesn't does anyone know what I would need to get what I want. A HTPC is out of the question, no room for one, that is what has attracted me to this little box of tricks.
    28. looun
      looun
      Jun 26, 2015
      27
      rome
      +7
      yes you can, Q5 support net share folder with SAMBA like PC but speed it's not fast 20-30Mb/s.
      The best solution always is NAS, more fast and more flexible.
      here you found all information about q5 HiMedia Q5/Q10 4K3D
    29. PC Nut
      PC Nut
      Jan 11, 2004
      651
      South West
      +65
      NEW BOX COMING SOON if you didn't know
      HERE
    30. hodg100
      hodg100
      Aug 8, 2005
      14,105
      3
      4
      +4,468
      Yes indeed, I should have a review sample soon.
