Question Hikvision supplier
Discussion in 'Smart Home, Climate Control & Security Forum' started by RainbowShooter, Apr 16, 2016.
Tags:
  1. RainbowShooter
    RainbowShooter
    Feb 26, 2014
    41
    11
    St Albans, Hertfordshire
    +6
    Looking at getting some Hikvision kit soon, (NVR and around 8 cameras). Any one have any recommended websites/suppliers to source the kit from?
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    We trialed Hikvision as our camera of choice for our installs, along with many others but finally decided on GrandStream.
    CCTV
  3. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    I bought mine from iCCTV and they were much cheaper than anyone else.
    So much so, that i got the DS-7208HQHI for less than most people charge fr the HGHI version.
    Not only were they cheap, their service (nost pre and post sales) had been excellent as they has replied to my multiple emails within a matter of minutes.
    I should point out that i am not affiliated with them in anyway, but they deserve recognition for being so helpful.
    Jon
  4. RainbowShooter
    RainbowShooter
    Feb 26, 2014
    41
    11
    +6
    Thank you both.
    @seb, I've pretty much settled on HikVision now, just wanted to do the final check with members if they've found any good suppliers for it all!
  5. Swynol
    Swynol
    May 28, 2009
    393
    +31
    good choice on hikvision. i tested both a UK branded hikvision camera and a cheaper Chinese branded hikvision from ebay.
    both were exactly the same, I heard of issues where the menus wont be english but can confirm they are english.
    the model i bought was DS-2CD3132F-IW for under £60 (uk price is around £120) they are 3MP. only issue i have with them is IR bleed at night (UK model also suffered) but that is due to them being dome cameras.
  6. jonna
    jonna
    Mar 25, 2002
    3,187
    Cheshire
    +2,459
    I got mine from Netview home, really helpful and they also sell on Amazon which makes life easier if you have an Amazon account.
    Highly recommend the 4MP Hikvision Turret Dome IP Cameras. Basic setup is done on the NVR and more advanced settings are done via Web.
