Thank you,
The blend rig has loads of things to think about, so sometimes I get a bit muddled up with all the different things going on at the same time........
I also seem to have exceeded the DVI bandwidth
AND something I did not consider but now realise (was real obvious if you think about it....)
IF my blend rig is to run at (just picking a figure) total 1920x1080 and use a 512 pixel overlap then the actual resolution needs to be 2432x1080 , each PJ running 1216x1080
(NOW I see why Tims 1280x1024 for each is very close to actual required size)
Last night I was running at 3840x1080 , I forgot to add the blend area on top, so actual resolution should have been 4352x1080 , the idea was to go double H resolution of 1080p
of course 4352x2160
would be better......
But the national grid are not happy
Actually latter today im gonna try that! Just for fun.....
THEN I think I will put my sensible head back on and decide the actual final resolution........
People might ask "If the PC blending does not work why bother?" , I would have to say, thats the wrong question! nudge, nudge,
