High Speed Dubbing
Discussion in 'Blu-ray & DVD Players & Recorders' started by davet010, Sep 24, 2004.
  1. davet010
    davet010
    Jul 23, 2004
    385
    +10
    I'm thinking of buying a HDD/DVD model (prob Panasonic e85 or e95), mainly so that I can dub things onto disk at higher speeds.
    Am I right in thinking that the disk copies won't maintain 16:9 ration unless done at 1:1 speed ?
  2. nialli
    nialli
    Apr 16, 2004
    469
    28
    +25
    Sort of. From what I've been able to work out, the E-85 has two settings when recording: one regular, one that enables hi-speed dubbing. Only the former retains the widescreen tag. You can only do hi-speed dubbing to DVD-R or DVD-RAM if you make the original recording for the latter, so you lose the 16:9 setting both on the hard disc copy and any DVDs you subsequently burn.
    I now record everything without the hi-speed option as scrolling through the TV remote display settings for 16:9 infuriates the missus! It also means that my DVD-Rs play in the right ratio on my old DVD player in the bedroom on a 4:3 portable.
  3. davet010
    davet010
    Jul 23, 2004
    385
    +10
    So I can still alter the TV to 16:9 ? Do the recordings look stretched or normal ?
    thanks
    DT
  4. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    As Nialli has stated (with some manufacturers, eg. Panasonic) the widescreen flag isn’t recorded during a high speed dub to DVD-R. If you have a widescreen TV (and you’re not Nialli’s missus!) then it shouldn’t be too much of a problem to switch it to 16:9 manually and the picture will appear normal.
    However, if you have a standard 4:3 TV (without an anamorphic mode) then there could be a problem with widescreen material from the E85/95 as DVD players won’t automatically letterbox it and the picture will be stretched vertically.
    Other manufacturers such as Toshiba do record the flag.
  5. jesmat2003
    jesmat2003
    Mar 8, 2004
    74
    I have a standard 4:3 television and have never encountered this problem with my E85.
  6. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    You haven’t elaborated, but maybe you only dub in real-time? What we’re saying is that if you dub in high speed mode on the Panasonics then the widescreen flag is not set on DVD-R (unlike DVD-RAM). This means that equipment used to replay the video cannot distinguish between a 4:3 picture carrying a 16:9 anamorphic image and one carrying an image with a standard 4:3 aspect ratio. Hence for a widescreen recording the picture will appear stretched vertically on a 4:3 TV unless your DVD player or your TV allows you to manually override it and produce a letterbox image with black bars top & bottom.
  7. jesmat2003
    jesmat2003
    Mar 8, 2004
    74
    I never dub in real time if I can avoid it, so always tend to use high speed dubbing. When I dub a widescreen programme to DVD-R it plays back fine on my 4:3 television. The television doesn't offer the choice to override any signals, I just use the settings on the DVD player.
  8. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    So you’re not changing any setting on the player but it somehow ‘knows’ the difference between a 4:3 frame intended to be shown 4:3 and one intended to be shown 16:9 (but still flagged as 4:3). Apparently your player is psychic :eek: Well you’ve got me stumped for the moment :confused: …….Anyone?
  9. davet010
    davet010
    Jul 23, 2004
    385
    +10
    Sorry, I guess my original question was unclear. I have a widescreen TV, and my question was whether a recording would retain the appropriate aspect if you use high speed dubbing.
  10. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    You have a widescreen TV so there's no problem as long as you don't mind manually setting it to "wide" mode (or the equivalent).
