High Resolution TV tuner box
Discussion in 'Plasma TVs' started by pc99, Oct 22, 2003.
  1. pc99
    pc99
    Feb 28, 2001
    255
    Milton Keynes, United Kingdom
    +3
    I think that LCD TV's are still too expensive compared to PC monitors.
    For £400 you can get a 1280*1024 19" LCD monitor, as opposed to a 15" TV with only 640*480 resolution.
    However what I've had no joy in finding so far is a TV tuner box with RGB output (like the ProV) which outputs a 1280*1024 signal. They all seem to only output up to 1024*768 and unfortunately the monitors I've tried them with don't scale the image to fill the screen.
    Does anyone know of a reasonably priced box that outputs this higher resolution?
    Thanks in advance
