High quality pre-amp for stereo
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by TheSeer, Nov 21, 2004.
  1. TheSeer
    TheSeer
    Dec 23, 2001
    142
    Hampshire
    +3
    Hello all,
    I'm looking to buy a high-quality pre-amp for stereo only listening. It will be used to feed a MF A308 Power amp.
    The budget is appx £1,000 (new or used) and remote functionality is essential.
    The obvious choice is a MF A308 Pre-amp but I'd be very interested in hearing about other options from people.
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Could look to the Linn AV5103. It's a 5.1 but the audio stage is outstandingly good. Available for just over £1000 s/h.
  3. 337GUS
    337GUS
    Nov 1, 2000
    751
    NE Scotland
    +38
    Somewhat biased but the 308 preamp is very good and you should get a used/ex dem one for £1K :)
    How about a 308 integrated and then biamp, I have been considering swapping my 308 pre for an integrated 308, I need to get a dem to see if it's a viable option to adding another 308 power.
    The Linn 5103 is widely regarded as an outstanding 2 channel preamp however.
  4. Timmy C
    Timmy C
    Oct 10, 2003
    5,110
    +382
    I just bought an Arcam C30 that I'm very pleased with but haven't heard the others mentioned here so can't say how it compares. If you're interested you should be able to find an ex display one to fit your budget and it's fully remote control too!
