High Quality Mains Cables?.
Discussion in 'Cables & Switches' started by Hysteria, Jun 9, 2004.
  1. Hysteria
    Hysteria
    Is there achauly any point in spending £40 on a mains cable?.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    No, for less than a tenner you can make your own that's probably better. If you can cope with wiring a plug of course ;)
  3. Hysteria
    Hysteria
    Ah cool, Will there be any benefits from a decent cable?.
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I've got one of these connected to my sub:
    http://imageevent.com/sidandcoke/sidsposhpowercord (not my site)!
    It's lowered the noise floor a bit but I've not noticed any other significant benefits. There's a good sticky at the top of this forum about DIY mains cables, also look through www.tnt-audio.com for help. Even just getting a thicker bit of cable and some plugs will make the cable look nicer than a kettle plug ;)
  5. Hysteria
    Hysteria
    Prob is my reciever has got a fixed cable, i'll have to do some modding. It's just an awful lot of work so i was just making sure it's worth it before i mod it.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    If it's a fixed cable I wouldn't bother. At least, I havn't with my equipment that has fixed cables.
    Up to you though ;)
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    what is the deal on a decent cable for mains use these days? Im a bit out of the loop having given up when I couldnt come up with something adequate in place of the pirelli double shielded
    ad
  8. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    It's going to depend very much on what equipment you have,and it's price level.....by that I mean that a number of amplifiers are relatively independent of cable design etc,esp those with regulated or regenerative power supplies,and as for price level,if you have a relatively low cost amp,I certainly wouldn't spend a lot on expensive mains cables for it.....at the upper end of the scale,good quality cables can make an enormous difference to sound quality,as can a decent ring main or spur....but that's another matter entirely!
