High quality image
Discussion in 'Blu-ray & DVD Players & Recorders' started by Me, Jan 1, 2002.
  1. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    Could anyone help me with some advice.
    I have a Sony CX-850 DVD player which is linked up to a Sanyo PLV-30 projector connected via S-Video. I also have a Pioneer DVD606 which is connected via component. The image quality from both is exceptional but the Pioneer due to the component connection is better. I am looking to get another player a Sony-CX-860. Same as the CX-850 but with component connectors. Will the image quality from the CX-860 with its component connectors be better than the old CX-850 with S-Video. Will it be better than the Pioneer or as good, I am not sure if the Pioneer is progressive scan or not?
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,654
    7
    167
    Birmingham, UK
    +10,540
    Well in theory, component is better quality than s-video.
    If your projector has a VGA input then you might want to think about using a home cinema PC which is progressive scan and picture quality wise, will wipe the floor with any stand-alone DVD player.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    I have recently upgraded from the Pioneer 606 to a 545 and the improvement in picture quality is noticeable.
    I don't know whether this is due to the change from s-video to RGB or the general improvement in DVD players in thye last three or four years.
    In theory if I can notice a difference on my 32" TV you should be able to notice even more on a projector.
    Ian
  4. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    Ian do you know if the Pioneer 606 is progressive scan or not or does it output a standard component signal?
    Mark.
  5. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    no the pioneer 606 is not a progressive machine it is just sending out a component signal!!
    hope this helps
    jason
