High Quality F-type connectors
Discussion in 'Satellite TV, Sky TV & FreeSat' started by milanlad, Sep 25, 2003.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Where can you buy High Quality F-type connectors?
    Any suggestions?
  2. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    http://www.lektropacks.co.uk/ have excellent RF plugs, but I've often thought the same about F-type connectors.
    Therefore ditto, any suggestions?
    StooMonster
  3. Fernsehman
    Fernsehman
    High quality in what respect? It's just a lump of metal that you screw or crimp onto the cable. Most are nickel plated brass and quite resistant to corrosion. Obviously the main criterion is that impedance mismatch is minimised. Not easy to measure!
    Fman
  4. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    High quality looks, what else?
    StooMonster
  5. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    I'm looking for 'high quality' in terms of electrical and mechanical characteristics.
    Also, trying to find connectors which are easier to attach to the cable.
  6. mattheu
    mattheu
    In my field of work, F connectors seem to be poorly made compared to other RF connectors. Have you looked at CPC or RS? There is a US supplier 'Pasternack' which has the most comprehensive little catalogue, they are cheap and very helpfull and will deal with small quantities.
    As for impeadance mismatch, hopefully the manufacturer has done the job correctly. Some cheaper supplier ( no names) look good intially, but tarnish over time.
    Lump of metal eh! I hope they have the decency to machine it!
  7. Arthur Dent
    Arthur Dent
    Never had any problems with the Maxview ones sold in B&Q and the like :)
