High level lead HELP
Discussion in 'Subwoofers' started by eric3, Jun 10, 2005.
  1. eric3
    eric3
    I have a REL Stampede sub. I had to replace the high level lead. So I ordered a new one from Chord. The old REL high level lead is connected with:
    Yellow - Left, positive
    Red - Right, positive
    Black - Left negative
    When the Chord lead arrived there was no yellow connection but one red, one black and one blank. I got back in touch and was told they should be:
    Black - Left, positive
    Blank - negative
    I was never sure whether this was correct so I thought I would email Chord to double check, the reply I had was:
    Red - Left, negative
    Black - Right, positive
    Blank - Left, positive
    To me this still does not sound right, does anyone know how I can tell which is the right configuration? I completely lost and have no idea how this works.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    According to the BKXLS200...
    Red: Red Terminal Right
    Yellow: Red Terminal Left
    Black: Either black terminal
    Realise that it's not the same sub but it is consistent with your original lead...PJ :)
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    REL used to wire up their leads differently from standard but I am not sure whether they still do. Best thing is to contact REL directly and ask them.
