High Level cable compatibility
Discussion in 'Subwoofers' started by darkeeboy, Mar 20, 2005.
  1. darkeeboy
    darkeeboy
    Jan 8, 2005
    860
    28
    +34
    Can anyone confirm that the high level speakon cable for the rel will fit the mj acoustics sub? I cannot find any cheap supplies of this neutrik cable apart from rel ones.
    TIA
    Paul
  2. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    AFAIK it'll be fine - I nearly bought a REL one too, as I've got an MJ Acoustics sub too, but was offered an MJ Acoustics cable at a reduced price.
    I never realised that adding the high level connection would make such a difference!
  3. darkeeboy
    darkeeboy
    Jan 8, 2005
    860
    28
    +34
    can i ask where you got yours from? Ive been quoted £30 for it and think its a bit steep - you say its worth the benefit - did you add it to your main fronts or centre speaker?
  4. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    Got it from the local Sevenoaks, and managed to get a few quid knocked off as a favour. It's wired to the front speakers and it's made a noticeable improvement to performance with music.
  5. darkeeboy
    darkeeboy
    Jan 8, 2005
    860
    28
    +34
    cheers for the info - one more q if I may - did you change your speakers to "large" or keep as "small" on the av amp?
  6. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    Good question, actually! Have a feeling that I have them set as large, so that the high level connection gets a full range signal. Will check tomorrow, can't at the moment.
