High end soundcards with internal line outs?
Discussion in 'Computer Components' started by Big Adam, Sep 22, 2005.
  1. Big Adam
    Big Adam
    May 7, 2003
    509
    Peterborough
    +4
    I've just sent off an email to mCubed technical support on this subject but wondered if anyone here had a clue! :rolleyes:
    I've been looking through some reviews on the mCubed HFX case and almost none of them make any sort of mention of the RCA plugs on the back of the unit:
    [​IMG]
    The only one I've found is a french one which included these two pics:
    [​IMG]
    [​IMG]
    The review shows the plugs linked up to an Audigy 2 via some cables which are included with the case. This intrigues me as I've not come across any other HTPC case which emplys anything similar.
    I've asked mCubed if the RCA/Cinch jacks may be all be used as 'outs' and if they have a list of approved cards which support these connections.
    What I'm really interested in is whether I could make use of these connections with my power amps? If so, what decent cards could I use?
    I'm assuming of course that the volume could be adjusted through windows. No point setting this up if the internal connection is at 100% 'signal' level only. (apologies if my terminology is upside down) :suicide:
    Any ideas?
  2. Big Adam
    Big Adam
    May 7, 2003
    509
    Peterborough
    +4
    Anybody?? :rolleyes:
  3. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    rme 9632
  4. Big Adam
    Big Adam
    May 7, 2003
    509
    Peterborough
    +4
    mCubed's list of offically supported cards consisted of:
    Creative Audigy.......and that's it. :suicide:
    Must be others (preferably somewhere between these extremes) that will achieve the same results?
  5. matro
    matro
    I though it could be able to link such plugs with the back side of the jack connectors...
