High End DivX Compatible DVD Player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by stevearliss, Apr 18, 2005.
  1. stevearliss
    stevearliss
    Feb 4, 2005
    64
    To save having to have 2 DVD players and to reduce the number of inputs I use on my AV Amp, does anyone know of a good quality DVD Player that will play DivX/XviD from DVD; something of equivalent PQ as the Denon 2910?
  2. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    Read the various posting about divx. High and divx, Pioneer 575 Philips 720 / Yamaha 550 is as high end as it gets. All divx players currently have a chip by mediatek, Zoran or Sigma regardless if they are El cheapo chinese player or a top brand. The Pioneer / Philips / Yamaha I've listed about all have the a mediatek chip.
  3. stevearliss
    stevearliss
    Feb 4, 2005
    64
    OK, they are the best I have come across. Granted I haven't demoed them for normal DVD play against something like a Denon 2910 but I assume you do get something extra for the money with the Denon.
  4. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +60
    When I bought my Denon I was told I'd be better off spending £50 on a cheapo player just for DivX. It isn't the neatest solution but why compromise if you're looking for good DVD playback?
  5. ilrenato
    ilrenato
    Nov 26, 2004
    23
  6. stevearliss
    stevearliss
    Feb 4, 2005
    64
    Unless I go for some form of PC solution, a separate DivX DVD Player seems to be the best route; it just leaves the issue of the number of components I try to connect to my AV Amp. At least the PC solution would bypass that and go straight into the VGA socket.
