High-end dilemma - Adding channels while keeping my hi-fi pre-amp in the loop
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by MJeeves, Sep 13, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Hi All,
    I want to add DTS 6.1, DD5.1 EX, Dolby Surround II etc etc to an existing Hi-Fi System that I am very fond of. Is there a quality home cinema amp, processor, receiver out there that I can use for centre and rear channels as well as providing an output to my current high-end pre-amp for the main left and right channels? Will I still get proper DTS and DD5.1EX etc etc?
    Thanks for your assistance.
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Take a look at the LINN range of system controllers, Kisto or Exotik should do the trick depending on how Hi end you wish to go.
  3. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
  4. simoncope
    simoncope
    What is the current pre-amp that you have? You say hi-end, but then dismiss the Linn gear as 'too' hi-end...
    Is the quality of the surround sound you want on a par with your expectations for stereo listening?
  5. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    My current pre-amp is an Audio Research SP9. The Linn's are too expensive at this moment in time. I'm thinking of going for a Denon AVR 3805. Any thoughts?
