High Definition/WXGA Screen
Discussion in 'Plasma TVs Forum' started by remdude, Jul 28, 2004.
  1. remdude
    remdude
    Jul 21, 2004
    69
    Can anyone tell me, what if any, is the difference detween a High definition display (as defined by Panasonic, TX32LXD1) and a WXGA display (as defined by Philips 32PF9986).
    Thanks for your help
    :lease:
    REMDUDE
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    They are the same resolution, 2 ways of describing the same thing. Personally I think that W should actually be a 'w' as they are both 15:9 not 16:9. There are several recent threads on the subject. Try a search for 15:9 for more info.
