High Definition picture wanted from old XBox 360
Discussion in 'Xbox Forums' started by Shenoizy, Feb 8, 2009.
  1. Shenoizy
    Shenoizy
    Oct 24, 2005
    372
    +23
    I have a friend's old XBox 360. I don't know much about this console but since it does not have an HDMI output I wondered what options I have to get high definition pictures from the machine.
    It has the (standard) AV output but the only cable/adapter he has given me is one that connects to a SCART cable. I presume this can only output standard definition (up to 576p) so what sort of cable/adapter do I need to output high definition - will it be component output?
  2. kempez
    kempez
    May 25, 2008
    3,754
    Basingstoke
    +281
    You want a high def Xbox 360 AV connector. Either an Xbox 360 Component AV cable or an Xbox 360 VGA Cable
  3. Hillskill
    Hillskill
    Moderator/Games Reviewer
    Mar 10, 2005
    22,842
    Somewhere being wrong but staying strong
    +5,647
    Component and VGA are the two types of Cable that can deliver HD pictures from an Xbox to a TV/monitor. Composite is a very low end SD cable.
  4. kempez
    kempez
    May 25, 2008
    3,754
    Basingstoke
    +281
    Yep I know that, got the names confused :p I had a couple of 360's with component cables...and VGA
  5. Hillskill
    Hillskill
    Mar 10, 2005
    22,842
    +5,647
    Easy way to remember. Composite =composh*te :rotfl:
  6. Shenoizy
    Shenoizy
    Oct 24, 2005
    372
    +23
    Thanks guys. I thought as much but just wanted to check. I'll find one of these on eBay and see if it works.
