High Definition on X-box to Plasma / PJ
Discussion in 'Nintendo Forums' started by karl, Sep 9, 2003.
  1. karl
    karl
    I`ve just bought a pre-modded (X-ecuter 2.2 lite) X-box thinking I can output to a plasma or projector in 480P / 720P.
    I am beginning to wish I bought a US x-box.
    I understand UK X-box`s don`t output progressive scan (high definition) - or at least not without further fiddling.
    I have a component lead purchased from consoleplus.co.uk - alternative to high definition pack.
    I believe I need to make my x-box think it is a US model then connect the lead (or high definition pack).
    How do I do this - is this where evolution X comes in and how do I go about it ?
    One of the main reasons for purchasing the X-box was the prospect of sharp images on the big screen.
    Thanks for any tips.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Nothing to do with Evo-X. You need to get the video mode selector disc.
    Neil.
  3. karl
    karl
    Thanks.
    Next question - where can I find that ?
  4. wod
    wod
    Sep 7, 2003
    196
    +3
  5. karl
    karl
    I think I`ve found it on megagames.com.
    Just need to burn to a CD-RW to get it to work - I think.
  6. Dax
    Dax
    I'm in the same boat as you, karl. Did you manage to get the video select program to work? I got it from megagames but my modded XBox refuses to run it (I've tried burning the iso in Nero and Record Now DX). Can someone please offer some advice as to what I may be doing wrong? The solitary reason I chipped my XBox was to allow hi-def for running on my plasma but now I can't get it to work. :(
  7. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Do a full erase the CD-RW before burning the image on to it.
    Neil.
  8. Dax
    Dax
    That shouldn't be necessary if you use a brand new (unused) disc though, should it? Or do you have to format the disc first or something? Any and all help is most appreciated.
  9. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    I found that by erasing a new disc then burning the image onto it that it would boot no problems.
    Neil.
  10. spidermanalf
    spidermanalf
    Oct 25, 2002
    1,987
    63
    Wakefield
    +103
    A shop near me sells them they are 5 qud a pop I think, it lets you choose NTSC/PAL if anyone has a DVD r/w I will gladly post them mine (as long as I get it back!)
  11. Dax
    Dax
    Just tried it now and it works! 480p is amazing -- looks so much better now. Thank you so much, Neil. :)
  12. karl
    karl
    I copied the ISO to a CDRW - this didn`t work.
    I did a full erase of the disk then selected "Burn Image" from Nero menu - the disk works now.
    480p definitely looks sharper and brighter.
    Sorry for the delay in posting - haven`t been online for a few days.
    Cheers.
  13. Dax
    Dax
    The thing that amazes me is that PAL games that usually only run in 50Hz (Halo and Genma Onimusha, for example) still work and output 480p when in NTSC mode -- wasn't expecting that. :)
  14. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    glad it works guys...
  15. TwistedPear
    TwistedPear
    Sep 14, 2003
    20
    Stratford upon Avon
    What is this XBOX application called (the video switching app). Must you install via a disk, or can you FTP it onto the Hard Disk? I've looked on megagames.com, and couldn't see any reference to it - is it me?
  16. Dax
    Dax
    Megagames calls it "Enigmah PAL/NTSC Selector" and it's in the Patch Tools section within their XBox Utilities page. The file on the site is a RAR (like a Zip file), so you have to extract it. You are then left with an ISO file that's easy to burn to CDRW when following Neil's advice.
  17. TwistedPear
    TwistedPear
    Sep 14, 2003
    20
    Stratford upon Avon
    Thanks Dax... outstanding
  18. inzaman
    inzaman
    Dec 16, 2002
    7,883
    Derby
    +935
    Karl, does the high def lead that you got from console plus include an optical or coaxial slot or lead for connecting straight to an av amp, thanks
  19. pj
    pj
    Mar 15, 2002
    2,199
    87
    w.mids
    +324
    sorry to be a pain! but can someone give me the simplest/cheapest rundown on getting prog scan out of my uk xbox
    i got
    uk xbox non modded
    the official hdtv pack(but pic is very soft and has visible vertical streaks, hopefully cleared up with prog scan)
    pt ae-100 projector
    so...which chip is best(i still wanna use xbox live)
    and which vid selector is best to go for!
    thanks
    PJ
    p.s. do most games work in prog scan i.e the Uk ones i already own or are there specific titles only:confused:
