High Definition Feed From Euro 1080
Discussion in 'General TV Discussions Forum' started by RTFM, Dec 4, 2003.
  1. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Today we installed a feed from Europe's first High Definition satellite channel, Euro 1080. Although broadcasting does not start officially until 01/01/04, they are broadcasting a variety of HD material all day for test purposes.
    The set top box will output 720p or 1080i as well as downscaling to 576p or 576i
    The quality through a good projector is outstanding. It compares very well with the High Def material we show from D-VHS tapes from the US on our Sim2 projectors.
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Jeff,
    What set-top box are you using and where did you source it ? Do you need a card for the feed ?
    Thanks,
    Sean G.
  3. Kramer
    Kramer
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Sean, the STB is from Zintec in NL.
    It's a Zinwell ZDX-410HD
    No card needed as it's FTA
  5. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    K, Jeff,
    Thanks.......... have to re-think that letter to Mrs. Santa.......;)
    All the best,
    Sean.
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Sean,
    email me at projectors@eurobell.co.uk and I will send you some more info on the HD STB and what you need to receive it.
    Jeff
  7. Kramer
    Kramer
    Moved to Hi Def forum :)
  8. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Thanks Kramer,
    Excuse my ignorance, I was not aware of a HD section.
    Jeff
