High Definition AV Pack for European/PAL Xbox?
Discussion in 'Xbox Forums' started by Kain, Jun 14, 2002.
  1. Kain
    Kain
    Jun 11, 2002
    265
    16
    Dubai, UAE
    +3
    Is there a High Definition AV Pack for the European/PAL Xbox? If not, how am I meant to connect it using component inputs/outputs?
  2. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    hi its not available for the european version,but the american version works with a uk xbox!!
    you can either import one from dvdbox office,lik sang ,or if you try raven games in bromley i believe they have them in stock
    jason
  3. Kain
    Kain
    Jun 11, 2002
    265
    16
    Dubai, UAE
    +3
    Oh, thanks! :)
    BTW, do you think I should use the American High Definition AV Pack or the European Advanced Scart Cable for the European/PAL Xbox?
  4. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    thats up to you depends what you want to connect it to and and what connections you have!!!
    i have the high def pack for use with my projector, and the after market lead with scart and s video for my tv
    if i had known that i couldnt recieve 480p from a uk xbox i dont think i would have bothered with the high def pack,just hope someone comes up with a hack to enable it :)
    jason
  5. Kain
    Kain
    Jun 11, 2002
    265
    16
    Dubai, UAE
    +3
    Actually, I meant is there any difference in picture quality between the High Definition AV Pack and the Advanced Scart Cable with a 480i game?
