high def what products will use what connections?
Discussion in 'General TV Discussions Forum' started by shoestring25, Jul 2, 2005.
  1. shoestring25
    shoestring25
    Feb 2, 2003
    3,893
    essex
    +435
    now i know skys high def service will use HDMI so thats one sorted out and im assuming which one of the high def dvd formats wins (either HD-DVD or blue ray) will use HDMI as well? what are the PS3 and Xbox 360 use as there connections for high def? am i right in the conclsions i have already made?
  2. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,548
    +887
    PS3 announcements included it having TWO HDMI connections ISTR.
    I would expect the US versions (at least) of the XBox 360 and PS3 to also have analogue component HD outputs given that this is still the defacto HD interconnect standard in the US.
    (Can you imagine launching an HD product in the States that would not work with the vast majority of existing installed HDTVs?)
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,478
    Windsor
    +1,046
    How much will 4-way HDMI switchers go for!?
    PS3, HDTV, PC maybe. At least with PS3 you might not need another bluray player, and Xbox 360 currently only has analogue outputs.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,891
    The Borders
    +3,117
    Hello Richard
    A couple of options were already stocking/supplying/using:
    Zektor DVS5.1 DVI (with HDCP) + Optical/Coaxial Digital switcher - UK SRP 380.00 GBP.
    See http://www.zektor.com/dvs51/index.html
    Gefen EXT-HD-441 DVI with (HDCP) Video only switcher - UK SRP 246.75 GBP
    See http://www.gefen.com/kvm/product.jsp?prod_id=2249
    Gefen EXT-HD-441A DVI with (HDCP) Video + Digital Audio switcher - UK SRP 282.00
    See http://www.gefen.com/kvm/product.jsp?prod_id=2654
    Gefen EXT-HDMI-642 HDMI Video with Digital audio Distribution switcher - UK SRP 634.00 GBP
    See http://www.gefen.com/kvm/product.jsp?prod_id=2758
    There are lots more products in the pipeline with full spec HDMI inc Multichannel audio support and 2x2 and 4x2 Distribution Switchers due very soon.
    Best regards
    Joe
    PS We also have loads of Two Input HDMI and DVI (with HDCP) products from Gefen.
  5. shoestring25
    shoestring25
    Feb 2, 2003
    3,893
    essex
    +435
    tvs never come with enough sockets alot of teles come wityh three scart but only one maybe two are RGB so you have to get a scart RGB switch box. the same will be true with HDMI at the moment they only come with one in a couple of years time they will come with two still not enough then in a few more years time three but im not going to wait maybe five or more years to get HDTV so i wil just get a HDMI switch box problem solved :clap:
  6. Mr Eddy
    Mr Eddy
    Feb 26, 2005
    220
    Xbox 360 component hd and possible vga support, no hdmi . You will need a component switch box not HDMI
