High Def TV's in the UK (xbox2 releated).
Discussion in 'General TV Discussions Forum' started by Pugger, Mar 14, 2005.
  1. Pugger
    Pugger
    Jan 14, 2004
    122
    Cardiff
    As it seems the big push from MS regarding Xbox2 is High defintion support, and being avid gamer I'm interested in buy a HD TV set. I'm unsure however how to spot a high def tv in the uk. Are most plasma and LCD high def compatible or is there more to it. I've seens a great deal on both the LCD ans Plasma Panasonic vierra but from the spec I can't make out if they are High Def compatible. Any info greatfully received.
  2. Astaroth
    Astaroth
    Jun 22, 2004
    3,708
    London
    +898
    There will shortly be a HD ready sticker available to manufactures to optionally declare their equipment. To be able to have the sticked they must be:
    1. Display, display engine
    • The minimum native resolution of the display (e.g. LCD, PDP) or display
    engine (e.g. DLP) is 720 physical lines in wide aspect ratio.
    2. Video Interfaces
    • The display device accepts HD input via:
    o Analogue YPbPr1, and
    o DVI or HDMI
    • HD capable inputs accept the following HD video formats:
    o 1280x720 @ 50 and 60Hz progressive (“720p”), and
    o 1920x1080 @ 50 and 60Hz interlaced (“1080i”)
    • The DVI or HDMI input supports content protection (HDCP)
  3. Rob20
    Rob20
    Jul 3, 2004
    3,282
    +779
    Best bet is to get the model numbers of the tvs your interested in and ask the forum. :)
  4. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
    Xbox are hi-def compatible too. You just need to softmod them.
  5. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,125
    can uk xbox's run hidef if so what mod is required and how much also are there any games that run in hidef thanks :thumbsup:
  6. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
  7. chillo
    chillo
    Sep 15, 2004
    786
    Northern Monkey!
    +35
    i thought my pioneer hd434 is compatible, but i think its native resolution is 1024x768 not 1280x768?
  8. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Don't worry, your 434 is compatible with the coming SkyHD platform. 720p and 1080i signals will be scaled to fit your panel.
    Steve
  9. gslater
    gslater
    Mar 18, 2005
    129
    London
    +3
    I can tell you a little bit on the plasma side.....
    The new pioneer plasmas are HD compatable (435xde), but as yet the panny plasmas are not. Waiting for the new panny 42" PV500 (out in May) which will be HD compatable. The HD7 has the correct native resolution, but it cannot receive the 1080i or 720p @ 50Mhz signal.
