High Def Connection
SuperWanderer
I have an LG 32LX2R which has one HDMI port (which doesn't work, see other thread), one DVI port and component input.
My HDMI port doesn't work so I have Sky HD connected through the DVI and audio in port and the Xbox 360 connected through component input. I'm after a PS3 but really don't want to shell out for a new tv just yet. Is there a way of connecting the PS3 to my LCD digitally?
Will it work HDMI to DVI? Does it have and audio out?
Thanks!
_Sion
remember that DVI is video only, so unless you put the audio through an amp you'll need an adapter to convert audio from the two phono (red/white) cables to a male 3.5mm jack to plug into the DVI audio socket on the TV.
I had a similar LG and used this setup.
