Hifi vs Home Cinema, can I have both on a budget
Discussion in 'AV Receivers & Amplifiers' started by Pword, May 18, 2005.
  1. Pword
    Pword
    I have a limited budget of £700 and would like a new hifi/Home cinema system.
    Am I fooling myself that I could get both. Instead of getting seperate amps and players I was thinking of getting a
    Amp: Yamaha 750SE
    DVD: Pioneer DV575A
    Speakers: Tannoy FX5.1
    This sounds alright in terms of the home cinema but I an not sure sonically.
    Can I play CDs through a DVD player and multi channel speakers and get a decent result?
    Do you have any alternative suggestions for kit, should I go for completely seperate systems?
    I would be grateful for any thoughts.
    Thanks.
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    You can get a reasonable sound from a dvd player and an amp like the excellent ax750. It will not be as good as a dedicated cd player but until you get one you wouldnt notice.
    My only problem is with the use of satalite speakers. I feel that you will neve get the same musical responce with them than with floostanding or bookshelf speakers.
    AX750 £352 inc
    Pioneer dv575s multi region £97:90 (+postage?)
    Total £453 ish leaving approx £250 for speakers and all cabling.
    Tannoy fx5.1 £200
    Or the replacement EFX5.1 for £259:50 inc stands, wall brackets and 25m of speaker cable :smashin:
