HiFi Upgrade Advice
Discussion in 'Hi-Fi Stereo Systems & Separates' started by TurnipFarmer, Mar 4, 2005.
  1. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    I need your advice guys
    My system at the moment includes
    Amp - Marantz 7200
    CD Player - Marantz CD63 MKII KI
    Turntable - Project Debut II
    Speakers - Acoustic Energy Aegis 2 (floorstanders)
    Im thinking about upgrading but not sure what to upgrade. I am a student so on a limited budget but I would like to know what you gurus would suggest and why
    Cheers dudes
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    Speakers dude.
    You have 2 good sources.
    Your amp is half decent
    Improve your speakers, In your shoes I would do the following, get the best second hand - exdem standmount speakers you can, then later on add an active sub to bolster the lower registers.
    Your system will then be in place for Amp upgrade & source upgrade. I would budget around £300-400 for your standmount speakers, then add a BKE 200 Sub for £200 Notes, that would be one serious speaker system (not beatable until £1000+ Floorers). Castle Durhams are available ina few places just £4 49 you could do the wholseale changes now.
    Just some thoughts. HTHs.
  3. TB Sanchez
    TB Sanchez
    Cant disagree with CJ there, although Ive seen a few of the old style castle richmonds kicking around at around £130-£140. Decent speaker even without a sub.
  4. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    CJ, whilst I agree with you, it might be worth telling him what the pitfalls/caveats/problems are in adding a subwoofer. For 95% of us, they simply aren't "plug'n'play" additions to a system ;)
    DT
  5. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    Thanks for your help guys
    The thing is with a me getting a sub is that my amp does not support sub plug in so it would not be suitable.
    What are the castle richmonds like? Is there any other floorstanders around £300-£400 you can suggest?
  6. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    You connect a sub via the high level connection to the speaker binding posts of your amp in tandem with your speaker cables.
    £300-400 Floorstanders ? Theres loads dude. But Im a standmount + sub fan so cant really point you in the right direction there, FWIW I would point you away from a set of floorers and towards the standmount+sub option.
    DT - I think suggesting a sub in tandem with standmounts are as valid a suggestion as saying floorstanders, at least you can tune and tailor the sound from a sub, you cant do that with floorers. Caveats apply with floorers too but are rarely mentioned.
  7. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    i always thought connecting the sub up that way degraded the sound quality compared to connecting it striaght to the amp?
    I just sold my sub ooops thinking that I would not be able to use it with this system,
    What do people think about a pair of Mordaunt Short's MS906 as a worthy upgrade from my Acoustic energy's?
  8. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    I have been looking around
    what about a pair of Tannoy Revolution R2's or R3's? These better then my AE Aegis 2's?
  9. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    sorry to keep going on like this but I have found a really cool deal.
    Found some AE Aesprit 309's for £149.50, did these not retail at £600ish quid when they came out?
    Might get them :)
  10. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    I think I will get the AE 309, just one technical question, will these work with my marantz pm7200?
    Or should i get the evo3 floor standers and just pay a bit more?
  11. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    does anybody know if these will work with my marantz pm7200 before i get them?
    The 309s have a max watt of 200 my amp has max watt of 95w and in class A mode they have about 25w
    thanks guys
  12. Hallsy
    Hallsy
    Nov 24, 2004
    685
    Suffolk
    +14
    I'd imagine that the 309's would be fine, they have a high sensitivity 90.5db I think, anyway, it's the same as the Evo 3's.
    I have just ordered two pairs of these, great deal at £149.95 a pair, I believe they were £700 when they first came out.
    Comparing to Evo 3's I don't which are "better" but I believe they were both being sold at the same time, however the aesprits were AE's midrange speakers, and aegis Evo's budget speakers (with no disregard there at all) so you would guess at the aesprits being better of the two.
    Also I have heard that the b-stock items have been received as good as new with no marks on them whatsoever. Hopefully mine will be like that ;)
  13. Withdrawnmist
    Withdrawnmist
    Doesn't your amp have a pre-out ? that would be where to connect the sub....please people correct me If I'm wrong..ta
  14. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    No, my amp does not have a pre-out which is quite strange
  15. davehk
    davehk
    Oct 17, 2003
    713
    28
    London
    +45
    There is no reason that connecting a sub to the speaker output would cause sound degredation, provided that the sub is DESIGNED to be connected this way (eg REL)
  16. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    ok. Too late now i have sold it lol (quite while back) however if I get another I will connect it that way.
    Im always learning lol
  17. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    so they would be ok?
