HiFi Problem
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Midge, Mar 4, 2005.
  1. Midge
    Midge
    Oct 2, 2002
    312
    Bristol
    +6
    Having trouble with my hifi in that everything plays ok for about 30 secs and then the sound cuts out. I've checked all the speaker wires and they all appear to be ok, anything else I can check, or is it just stuffed???
  2. la gran siete
    la gran siete
    Oct 5, 2003
    25,222
    Deep in the bowels of sussex where the angloargies
    +1,968
    Dont know but I would start by having the amp checked out firts( assuming you have seperates) You could always try your gear with someone elses to see ehre the problem lies- process of deduction.
  3. Midge
    Midge
    Oct 2, 2002
    312
    Bristol
    +6
    It not separates, just a Panny compact system.
  4. la gran siete
    la gran siete
    Oct 5, 2003
    25,222
    +1,968
    sounds knackered to me. You could try and get it sorted but it would probably cost more than its worth. Always buy seperates if you can then if one item goes wrong then youm only need to replace/repair that item
