Hifi Choice DualDisc Sampler
Discussion in 'Arcam Owners' Forum' started by Matt Horne, May 11, 2005.
Tags:
  1. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +136
    Hi..
    I tried this disc out tonight on my DV88+. DVD side works fine had a listen to the 5.1 tracks (not dvd-a as I do not have the card) and a peak at the videos.
    Tried the Cd side, comes up no disc!, it gets spat out of my mac's dvd drive (slot drive -- it loads in ok!) and reads the TOC on a older sharp cd boombox but will not play the tracks.. not a very impressive start to a new format !
    I hope this is mainly down to a cheaply produced sampler disc and not a indication of things to come.
    I have 3 US import Dual Discs on the way so I can test the real deal soon!
    Matt
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I tested this disc in the store on several machines. The DV78 played both sides ok but the DV79 and DV29 refuse to recognise the CD side.
  3. steeled
    steeled
    Apr 23, 2002
    485
    28
    Maidenhead
    +54
    Hi All
    I tried both sides in my DV27A and it worked without any problem.
    The article in the magazine did say that the DualDisc does not show the CD Audio logo because the CD side is not 100% compatible. It said that some DVD players and DVD-ROM drives may have probems with it.
    It said this was because the CD layer is not as reflective in a DualDisc as in a real CD. (I think this was because the CD "half" is thinner than a normal CD.)
    It said that if the drive has problems with CD-RWs then it might have problems with DualDiscs.
    HTH
    Dave
  4. nolispe
    nolispe
    Can you tell me where I can get such a sample disc? Is there a website or shop I can go to. Perhaps even a copy if it's not copyrighted.
  5. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    +136
    Its on the front cover of this months hif choice magazine.. try your local newsagent if you are in the UK!
    Matt
  6. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    have played the keane dualdisc on both sides on dv-89 without any problems have also tried the cd side on 3 other cd players a nd a portable radio cd player also no problems, did notice when playing dvd side on computer a couple of times the sound went quiter for a second during playback via multichannel dolby digital
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Update: All of the Arcam machines in the shop now play both sides of the dual disc, just needed a little laser lens cleaning.
  8. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    +136
    recommendations for a lens cleaner ??
    cheers
    Matt
  9. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
  10. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    +136
    Also whats the latest drive firmware available for the LT drives ? Myabe I should upgrade and see if that makes a difference! Still did not work after cleaning the drive!
    Matt
  11. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    +136
    Nope real Dualdiscs cd side so not work in my arcam :( just tried Miles Davis....
    Crustyloafer.. whats the latest disc firmware available for the LT series at the moment ?
    Matt
  12. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Not quite sure, LT78 I think, or is it LT76. Andy, Engineer or John will be able to give you a definative answer to that.
  13. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    +136
    I wonder if I can upgrade my firmware to the level that the DV79/Dv29 are at ? Or I wonder if the drive is a different model alltogether ?
