Hiding the Sub (!)
Discussion in 'Home Cinema Building DIY' started by xio, Dec 12, 2002.
  1. xio
    xio
    I am considering hiding the subwoofer in a yet-to-be-built window seat. Any tips on the housing that I should be aware of?
    Also, what kind of grille should I use ? - Do I have an open frame with material in front of the speaker- if so what kind of material should I use?
  2. paiger
    paiger
    Thats a good idea. I would assume some kind of gauze would be best for the cover. Speaker cover material is available I think but may be aesthetically pleasing.
    Steve
