Hiding the Sky box for a clean look.
Discussion in 'General TV Discussions Forum' started by sarge17, Jan 7, 2018.
  1. sarge17
    sarge17
    Apr 28, 2009
    194
    +29
    Im looking to wall mount a TV for the 1st time and a little unsure of a good clean solution for the attached Sky Box and was after some advice.
    I was going to have an electrical socket put directly behind the mounted TV but as i will need to have the Sky q mini box connected I'm forced to run cables behind the wall anyway i guess so may as well use the traditional socket near the floor. I saw a Cable box bracket which could be hidden behind the TV but i think I'm right in thinking the remote would only work in direct sight of the box.
    Ideally we would like any boxes kept out of view but without adding a Harmony hub and IR sensor I'm not sure how we can get around, what must be a, common problem.
    How has everyone else hidden unsightly boxes from "floating" TV set ups?
  2. chopples
    chopples
    Dec 24, 2009
    1,643
    116
    Wirral
    +805
    Hi Mate
    you will need to spend a little bit of money (£15) but the Q touch remote is bluetooth, I believe it can also be paired to a mini
    cheers
  3. razy60
    razy60
    Jan 13, 2008
    1,261
    83
    Eastbourne
    +320
    Why not get them to wire an HDMI port in as well, then you can hide the box elsewhere.
  4. sarge17
    sarge17
    Apr 28, 2009
    194
    +29
    Intersting, i don't use my Q remote for my other box (i use Harmony instead) i wonder if i can reprogram it to work on this box?
  5. chopples
    chopples
    Dec 24, 2009
    1,643
    116
    Wirral
    +805
  6. sarge17
    sarge17
    Apr 28, 2009
    194
    +29
    I knew there would be a simple solution. Thanks for your help
