Hiding the equipment
Discussion in 'Home Cinema Building DIY' started by Brad_Porter, Feb 18, 2003.
  1. Brad_Porter
    Brad_Porter
    Hi All,
    I am starting a project where I wish to pretty much conceal all my equipment in a customer built cabinet in my living room. The only thing I want on display is my TV and the speakers. (I wouldnt mind hiding the front speakers either actually if you have any suitable ideas....)
    Can someone please give me some solid and healthy advice on what to watch for here, especially in the below areas.
    1. Ventilation.
    2. Cable length issues (my scart may have to be 5 meters long - problems?)
    3. Pitfalls and common mistakes
    4. A check list of what I should be doing to make this project work
    5. Any other vital and important information on housing and hiding equipment
    If you need to know, the equipment I am hiding is a pre-amp, a power amp, a DVD player, sky box and video player. My room isnt large (12 x 12) and the dedicated space is very ample for all the equipment (chimney alcove) but wont take any monster constructions....!
    Any information will be much appreciated from any of you.
    Thanks in advance.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    There should be some info covering this in the DIY area if you perform a search.
    I'm sure others will help out later.:smashin:
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    ventilation im sure will be your biggest problem from your list..... with everything powered up there can be quite some heat, so just make sure there arent any external heating sources nearby..... and something i did, vent into the chimney or even a couple if the heat build up is large.
    ad
