Hiding the cabling
Discussion in 'Plasma TVs' started by Stampax, Aug 23, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,314
    Northampton
    +52
    So i've got the plasma - now I need to hide all the horrible cables.....
    Help!!
    What do you suggest, where is the best place to get stuff from? I guess I need some trunking, but would like something a bit nicer than the bland white plastic stuff you normally find in B and Q or homebase.
    Any ideas?
    This is what i've got so far.........
    [​IMG]
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    I take it you don't want to chase the walls and redecorate?
    John
  3. Sandman
    Sandman
    Nov 28, 2002
    3,184
    Glasgow
    +728
    Have a look at the "get you plasma's out for the lads" thread for some ideas.
  4. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    What are you watching in that pic?
  5. Stampax
    Stampax
    May 6, 2005
    1,314
    Northampton
    +52
    No I really dont fancy taking the walls apart - having moved in quite recently couldnt face any more majo decoration!!!!!!!!
    I think thats Kerrang music channel in - so it will be a music video on.
  6. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    185
    Is that fire surround solid? If not, you could (fairly) easily remove it and run the cables behind. You would need to chase the walls in a little at the bottom (as the entry point) and at the top between the bottom of the plasma and the fireplace. This is what I'd try to do.
    Alternatively, you could have a small piece of trunking between the plasma and the top
  7. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    185
    BTW that looks like some serious overscan going on in that picture.. have you set it to zoom? :eek:
  8. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    u should take the sticker off the tv ;)
  9. chaddy
    chaddy
    Jul 7, 2005
    1,617
    48
    Manchester
    +66
    its on wide aspect ratio, if it finds a channel that has small black bars at the top it scales it so the bars no longer show, you need to set it to 16.9
