I’m wanting to wall mound my rear surround speakers. It’s going to mean chiselling or cutting into plaster board then having it skimmed
Does anyone have any tips or tool recommendations? I’m sh*te at DIY. Thanks
I bought this tool to 'run' my electrical cables in the walls. Before I bought my home, it had recently been rewired and the sparky and/or homeowner took the quickest and easiest route of dropping all cables out in front of the wall and 'run' them in trunking that was stuck to the wall with adhesive. It looked ghastly.
So, I bought this tool:
• No load speed: 5,500rpm • Blade diameter: 89mm bore: 10mm • Max cut at 90º: 28.5mm • Laser cutting guide • Product includes: case, TCT, HSS, diamond blades Blades available: TCT , HSS and Diamond .
www.toolstation.com
It's basically a mini circular saw, come with all 3 types of blades for cutting types (metal, masonry and wood) and runs on a normal 230v household plug.
What you do is put the diamond blade on (masonry), adjust the guide (which is the flat plate to keep you flat and level) to the depth that you require and then you're good to go. You put the saw up against the wall, turn on and gently 'plunge' the saw into the wall and go FORWARDS and UP.
The next thing you'll want is an SDS drill with correct width chisel or doing it manually with a club hammer and bolster chisel (this can be hard graft depending on your bricks). Doing it manually, you may want to run the saw through the middle of the section that you're intending to chisel out since it will make it a lot easier to chisel the bricks out.
