Hiding ip
Discussion in 'ISPs & The Internet' started by adriandg, Aug 17, 2013.
  1. adriandg
    adriandg
    Oct 27, 2005
    400
    As the new American Footbal season starts I want to listen to my team play over Internet radio. The only problem is when I go straight to the site, which is 98.5 Sports Hub in Boston it's says this is not available in your country.
    I've tried using cover my ass but that doesn't work. So does anybody know of a free web proxy that would allow me to listen to US stations in the UK.
  2. hlpmeimdrowning
    hlpmeimdrowning
    Aug 11, 2010
    589
    2
    Coleraine, Northern Ireland
    +59
    I use hotspot shield free to watch the daily show online, so I would guess that it might work for you too.
    (Obligatory Rupert Giles quote)
    I just think it's rather odd that a nation that prides itself on its virility should feel compelled to strap on forty pounds of protective gear just in order to play rugby.
  3. adriandg
    adriandg
    Oct 27, 2005
    400
    Thanks I will give hat a try. Shouldn't need to be anything particularly fast as it is only going to be streaming radio.
    Didn't have clue what the quote was, but Google is your friend :thumbsup:
