Hiding equipment in a utility room?
Discussion in 'Home Cinema Building DIY' started by resseh, May 9, 2016.
Tags:
  1. resseh
    resseh
    Jan 5, 2008
    227
    28
    +55
    I'm trying to work out the best place to hide all my AV equipment.
    There is a tiny room to the right of the screen that would be perfect. But it's going to be turned into a utility room with a toilet and sink, dishwasher etc.
    Whilst I know that water/ humidity around electronics is very bad... Is there a way round it?
    Would it be safe to have the equipment in a closed off area in the utility room?
    The plan would be to have a poster on a door in the cinema room that opens up to see the AV equipment. And then in the utility room - all the equipment would be in a sealed off area with a door to access the rear of the equipment and then ventalation into the ceiling.
    I'm a complete novice at this so its all quite daunting
  2. resseh
    resseh
    Jan 5, 2008
    227
    28
    +55
    Seems I also have to worry about static.
    In theory I could just partition off a corner in the utility room and it should just be like being in a closet?
  3. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Get a proper comms cabinet in the partitioned area , but with good ventilation and watch the humidity. Ground the equipment and the cabinet to a suitable pipe
  4. resseh
    resseh
    Jan 5, 2008
    227
    28
    +55
    I'm building a false wall behind the tv - and will have hidden shelving to the side of the tv. Changing the utility room was not the easy option in the end - even without the water issues.
