Hiding cables when wall fitting?
Discussion in 'LCD & LED LCD TVs Forum' started by wdrury_uk, Jan 6, 2005.
Tags:
  1. wdrury_uk
    wdrury_uk
    You always see the picture of the LCD / Plasma on a wall but where are the cables to the RF / DVD / Sky / etc?
    Can someone explain hows this is done? I assume it through channelling the walls out and running cables. But does that mean I have to channel a new power point behind the LCD?
    Any help much appreciated.
  2. gazza166
    gazza166
    Jul 31, 2003
    826
    Plymouth
    +30
    As you say, it's more than likely channelling out the walls then replastering. I used some electrical trunking on mine which is not really noticeable but then it's in the corner and I've got white walls.
  3. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    The pics will often be 'staged' with products but no wires and pics 'pasted on'. Or the screens may be on thin partitioning to hide everthing.
    Look for the giveaway in the small print "Illustration for guidance purposes only" or similar.
    As for channeling out the wall - rotten job - and suppose you want to add or change a connection? You can get rectangular trunking in various sizes, which is 'U' shaped with a clip on cover and can be painted. Most DIY stores have iit and it looks tidy fitted on the surface of the wall.
    It may now be illegal to fit the power point you describe yourself. New regs came in Jan 1st about DIY electrical work. I think a simple spur may be OK though.
    For disappearing wires, look at any pic of a surround sound system - 6 speakers, amp, DVD player, CD player, VCR, TV, sat box - not a wire in sight - oh, and one titchy remote :D
  4. gazza166
    gazza166
    Jul 31, 2003
    826
    Plymouth
    +30
    I think you're right - the new regs are similar to Corgi regs for gas installations. Thing is though they are impossible to enforce; unless you annoy the wife enough to ring up the Police or whoever and say 'I'd like to report my husband for fitting a 240v socket to our lounge :eek: ' it's just not going to happen.
  5. John
    John
    Dec 13, 2002
    11,305
    +2,922
    Have a look at the Plasmas out thread .Lots of real life set ups ,"without" wires. Just like mine :D :cool:
  6. softg1
    softg1
    Jan 4, 2005
    Oh! I'd better stop annoying the wife.
  7. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
  8. cb31
    cb31
    May 17, 2004
    30
    That setup looks awful to my eye. Thousands of pounds on a TV and then 2.99 on a bit of trunking running down the wall...
    I cut out 2 channels and plastered over them, one for power and one for data cables. There are holes behind the TV with enough room in the channels to put in new and remove existing cables. Added a new power cable the other night for a mood light and it worked well. A lot more effort but looks stunning.
